Old 04-02-2014, 08:29 AM   #1
himbo
Drives: Lightening Red BRZ Ltd.
Lightweight REAR rotor options
I know there is the P&L lightweight rear brake upgrade as well as various lighter weight BBK kits. However, the P&L kit is hardly streetable while the BBK's are overkill IMO. I think the best compromise is installing lighter rotors for the rear. Problem is, I can't find anyone who seems to make them. I think knocking off a 2-3lbs per disc can have very noticeable effects to handling, braking, and accelerating.
Anyone wanna chime in? Some simple stock-sized, slotted rotors could do the trick. Maybe something with an aluminum hat?
Thanks in advance!
himbo is offline   Reply With Quote
Old 04-02-2014, 09:48 AM   #2
JerryMichaels7
Drives: Whiteout FRS
What makes the P&l not streetable?? Deletes e-brake?
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Old 04-02-2014, 10:10 AM   #3
himbo
OTE=JerryMichaels7;1643395]What makes the P&l not streetable?? Deletes e-brake?[/QUOTE]
Yeah for me streetable means ebrake. I know different people have different definitions of streetable, but that's where I draw the line.
I just think that a slightly lighter disc would be more than adequate and cost effective.
Old 04-02-2014, 10:16 AM   #4
ZionsWrath
Thanks
ZionsWrath's Avatar
My guess is something like that would be so niche, the cost would be halfway to a rear BBK.
Old 04-02-2014, 10:29 AM   #5
himbo
How so? There are lots of slotted or drilled rotors out there. Lots with aluminum hats. I'm just wondering if anyone makes them in the stock size. I'm not looking for ultra lightweight rotors. Just a slight and rather basic upgrade. Coupled with some SS lines and decent pads, a slightly lighter disc would make a noticeable difference in my opinion.
Old 04-02-2014, 10:55 AM   #6
wparsons
wparsons's Avatar
I don't think you'll ever find a two piece rotor with an aluminum hat that retains the stock e-brake functionality...
flickr
Old 04-02-2014, 12:23 PM   #7
himbo
Why is that? The drum is still there right? Isn't this just a matter of replacing discs?
Old 04-02-2014, 01:17 PM   #8
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
I wouldn't rule it out. They certainly exist for other applications, I've installed the Wilwood and the Stoptech setups on 350Z's in a past life. Here is an example for the Stoptech rear rotor for the 350Z. It integrates the drum inside the aluminum hat. They do state that you should absolutely not use the e-brake for anything other then parking however. Perhaps Stoptech builds one for our car since they offer it for other vehicles with a similar e-brake configuration?
mines13 is offline   Reply With Quote
Old 04-02-2014, 01:32 PM   #9
wparsons
wparsons's Avatar
The drum is part of the stock disc...
flickr
Old 04-02-2014, 01:59 PM   #10
CSG David
CSG David's Avatar
Would be interesting, but haven't seen anybody actually benefit with it. On paper and in theory, it should benefit performance, but the reality is it requires a trade-off that I'm not willing to take. Oh look, super fast acceleration from 0 to 20mph.
Old 04-02-2014, 02:16 PM   #11
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
I am intrigued by this question as well. I haven't seen any great solutions. The one in the above picture with the aluminum hat/drum may actually work for an emergency stop, ONCE. After that you will probably need a new rotor and possible some new brake shoes and/or other parts if the aluminum has melted. Good luck trying to drive home if the shoes fuse to the drums.
Old 04-02-2014, 02:45 PM   #12
CSG David
CSG David's Avatar
The easiest example that comes to mind is Robispec. He used 4lb rear rotors. He would snap them literally almost every session. Then he used 7lb rear rotors...it would last 1 to 2 full days. Keep in mind, his car is like 400lbs lighter than all of our cars...
Old 04-02-2014, 03:54 PM   #13
himbo
Aha! That explains it. Haven't actually seen the pics of the rear disc. I always thought the drum was seperated from the disc. Damn. That sucks
Old 04-02-2014, 04:03 PM   #14
JerryMichaels7
I agree with you OP. Just wasn't for sure if they did delete e brakes or not.
P&L STI Lightweight rear brake kit diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 57 05-31-2017 09:26 PM
Was tapped on rear bumper, options? drewbot CANADA 9 10-25-2013 01:13 PM
Aftermarket options for fixing up rear fender body edocura Cosmetic Modification (Interior/Exterior/Lighting) 1 08-13-2013 07:20 PM
Got rear ended on Saturday night. What are my options? Demotic Scion FR-S / Toyota 86 GT86 General Forum 25 07-16-2013 06:36 PM
Rear camber adjustment options? zooki Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 09-12-2012 11:46 AM
