Evap lines under the Intake Manifold - Easier fix?
I had to do the evap line clip install last night, which wasn't as hard as I thought it would be after reading up on it, but it was still fairly time consuming. Big thanks to whoever it was that suggested removing the AC Compressor. it made it 100x easier.
Anyways, I'm going to be installing an ECU controlled boost solenoid tonight which will mean my evap solenoid won't be used. If the evap solenoid is disconnected, couldn't you just run a vacuum line directly from the port behind the throttle body to the line near the drivers side fuel injector cover? I don't think there would be any issues since the evap system isn't connected, and if you haven't already installed the clips, you basically only have to deal with the throttle body clip and not have to remove your belt and AC Compressor. For others, this would turn a 1 hour job into a 10 minute job I'm thinking, and avoid all of the burns and cuts that come along with it. I did mine while the engine was hot, which in hindsight, probably wasn't the best idea haha ![]() Good idea or bad idea? edit: Also, since it's somewhat believed that the evap solenoid is fairly useless to begin with, couldn't you also bypass it regardless of it's connector being replaced by an EBCS?
#2 | |
I Love custom Turbo kits
Drives: Limited BRZ
Following your line of thought, you could install a line that is plugged in the middle thus not allowing air to move in between them.
#3 | |
i just removed my manifold, completely ditched the solenoid and put a vacuum cap/clamp on the port under the manifold that is used to hook up to. no more leaks, for good this time
Drives: 2014 FRS
Hmmm... Question: Is the evap solenoid normally open or close when electrically disconnected?
I had already put clamps on the hose from the evap solenoid and manifold so i just disconnected the wire and connected it to the EBCS. The evap canister solenoid is still there with all hoses connected and clamped. Is it a manifold leak now? thanks. |
#6 | |
Lacking brains
Drives: frz
I removed the solenoid and capped lines on my forester cause the barb broke. But here it comes at the cost of being on thin ice for emissions |
#7 | |
#8 | |
I'm not sure if that's correct or not, so take it with a grain of salt
| PSA: Clamping EVAP hoses under Intake Manifold, the easy way.. | Sportsguy83 | Forced Induction | 83 | 11-20-2019 04:15 PM |
| DIY clamping the evap vacum ports under the manifold!! | charged86 | DIY (Do-It-Yourself) Guides | 9 | 04-08-2015 07:56 PM |
| Intake Manifold | Bu-Tang | Engine, Exhaust, Transmission | 29 | 12-06-2014 02:43 PM |
| Oil on/around Intake Manifold | Wepeel | Issues | Warranty | Recalls / TSB | 2 | 05-13-2014 12:40 AM |
| WTB: intake manifold | carlitosway6891 | Engine, Exhaust, Bolt-Ons | 0 | 06-22-2013 03:24 PM |
