Drives: 2014 Toyota GT86
Crush Washer for AT
As the title stated has anybody here replace the ATF for their 86-BRZ?
If yes, what is the part number of the Fill and drain crush washer? Most that i read here are for MT only. Thank you.. |
Drives: Scion FR-S, Ultramarine
im fairly certain its the same part as it is MT
#4 | |
No, will prepare the crush washer so i can give it to the shop who will do the ATF oil change. I don't know whether it is the same as MT. |
Drives: AE86 & GT86
I'm pretty sure it's the same but, to be on the safe side just go to the dealer and have them look it up. Should just cost a few bucks
| Crush Washer Sizes | Eric1855 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 55 | 08-30-2021 03:21 AM |
| Washer Mod? | 636 | Engine, Exhaust, Transmission | 64 | 02-20-2018 05:08 PM |
| Can the transmission crush washers be reused? | brillo | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 04-15-2013 08:35 PM |
| front washer? | Filipino Royale | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-21-2012 03:06 PM |
| Man Crush A Friend's Car With A 100-ft Axe | ichitaka05 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 01-19-2012 04:31 PM |
