Drives:
Knocking sound in wheels during driving
I just installed the 30mm and 25mm eibach wheel spacers and I'm noticing a relatively loud knocking sound coming from the right front wheel. I'm taking it in Friday to get things done but I was wondering if I could get a preliminary assessment. What's going on?
'14 Firestorm FRS Build Thread: http://www.ft86club.com/forums/showthread.php?t=71248 |
Drives: 1980 corvette, 2014 Subaru BRZ
not tightened correctly
Drives:
Thank you for the quick reply. I have a 60 mile commute round trip.. you think it'll be good til Friday for when I get it fixed? I know it's not smart but I don't have much choice.
I have no idea, I would not trust it. but I don't trust spacers in general, in theory they are great but, unless you check them, the inside bolts can loosen and cause problems like this. Can you not pull off the wheels and check to see if they are tight?
Drives: 2013 DGM BRZ
What torque spec did you use on the spacers?
i do not use them, i would guess the same as the wheel, go in a star pattern to make sure they all get tight and seat well.
#7 | |
Drives:
Drives:
I wasn't able to. I only have the tire jack and a 3/4" socket wrench.
#9 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
#10 | |
Drives:
| Knocking sound | Moe23 | Issues | Warranty | Recalls / TSB | 80 | 04-18-2019 09:09 PM |
| knocking sound holding around 3,000rpm | radroach | Issues | Warranty | Recalls / TSB | 31 | 01-26-2018 02:03 AM |
| Knocking sound from what sounds like rear suspension | husker741 | Issues | Warranty | Recalls / TSB | 12 | 04-24-2017 06:26 AM |
| Knocking doesn't sound good :-(. | TheMarkness | Issues | Warranty | Recalls / TSB | 41 | 02-04-2015 11:38 PM |
| Bubbling/knocking (but not liquid) sound aside from chirping | mike_ekim1024 | Issues | Warranty | Recalls / TSB | 22 | 05-05-2013 04:20 PM |
