Drives: Scion FRS Firestorm
P0102 Mass or Volume Air Flow Circuit Low Input
Hey everyone,
I've been fighting the P0102 error code and I'm trying to figure out what to try next. The problem started with water that got in my intake. I have the FBM base stage 1 kit and i took all my piping apart and dried it out. Code came up after the drying. I thought water had burnt out the maf sensor so I ordered a new one. Installed it, code still there. Noticed the white wire on the plug going to the sensor was loose. It pulled right off. So i had a buddy help me solder it back in. Code still there. Can't think of what it could be. Thanks in advance for the help.
#2 | |
RWD addicted
Drives: BRZ 6MT OFT OFH
My case (same CEL code) was the rubber seal of the main motor harness, located near the battery. After the engine was installed back, i had the same P0102 and i started with changing AFR sensor first, what didnot cure CEL. Don't rememeber exactly how i found the bug in harness, but it was the reason of the lost signal from AFT to ECU. The harness' rubber seal just got swollen because of some silicone lubricant or cleaning spray used for the purpose of freshing the harness up ![]() So now i removed rubber seal out of the harnes and waiting till it fully dried up in ordder to install it back. It works fine without the seal though. Very strange compound used for makin the seal of that harness... Check your harness, mate! |
#3 | |
| MAF (Mass Air Flow) versus Speed Density, Discussion & Debate for ALL | DeliciousTuning | Software Tuning | 40 | 04-11-2015 01:56 AM |
| P0102, P0113, P2096 Engine code | Oburn | Engine, Exhaust, Transmission | 24 | 09-22-2014 05:30 PM |
| Unichip throwing p0102 code ?? | jdubz13frs | Software Tuning | 3 | 07-10-2014 04:27 PM |
| Car wont stay running for more than a second - P0102 & P0198 | STS-V | Engine, Exhaust, Transmission | 13 | 06-23-2014 02:37 PM |
| Mass FR-S Sighting | FR-STEVE | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 01-19-2013 11:57 AM |
