Old 11-29-2014, 01:50 AM   #1
pleong
Drives: 2013 Whiteout FR-S
Fender pull
What's the most anyone has pulled on their front and rear fenders??
I'm running 18x10 +40 with 285/30's
Fronts are pretty good at -2.5 camber and the rear is at -2
My rear needs to be pulled quite a bit
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
Old 11-29-2014, 11:21 PM   #2
N_A
Drives: 2013 Raven
Custom widebody should fix this. Rocket bunny would be ok too. You can go even wider.
N_A is offline   Reply With Quote
Old 11-30-2014, 12:55 AM   #3
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Option one: lower your car quite a bit more, correct static(natural) camber with adjustable lower control arms and toe links.
2: get upper & lower adjustable control arms if you want to maintain that ride height.
Source: I have the same wheels, I don't poke.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 11-30-2014, 12:59 AM   #4
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Oh... And my front fenders are rolled flat and pulled id guess about 7-10mm.
Rears: trimmed and pounded slightly (don't think I gained anything over my trimming
Omar GC
Instagram: 2jzus
Pick and Pull in Bay Area? oofie Northern California 10 03-08-2017 12:58 PM
Fender Roll/Pull FRS-IT Cosmetic Modification (Interior/Exterior/Lighting) 6 11-14-2014 11:45 PM
If they Pull The Plug exam2300 Scion FR-S / Toyota 86 GT86 General Forum 18 06-26-2014 12:59 PM
Help about to pull the trigger.... JerryMichaels7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 02-25-2014 07:12 PM
2007 STi... should I pull the trigger? RRnold Other Vehicles & General Automotive Discussions 25 02-23-2010 10:37 PM
