Drives: waiting on a 2021...
Subframe connectors?
Does anyone make full length subframe connectors for these cars? Or does the design preclude the fitting of them? I see various braces that either brace the front or the back subframes, but nothing that ties them together. It seem that every unibody type car benefits from tying the two together. Thoughts?
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
Drives: '23 BRZ Limited
Most modern coupes aren't going to benefit from subframe connectors.
It's not something like your Fox-Body that's based on a chassis designed in the late 70s without real FEA work. Even the S197 Mustang didn't really benefit from subframe connectors and that car was designed over a decade ago. The S550 is even stiff still. |
I was just wondering since TRD sells those little door jamb thingies. It seems that these chassis' flex a bit watching the videos. If the door is flexing that much it would seem the chassis needs a bit of stiffening.
Have any links to the parts/videos you are talking about?
I was reading through this thread:
http://www.ft86club.com/forums/showt...t=28367&page=2 Thee are a couple of videos posted shot from along the door that show it fixing a bit. The second one shows it better.
That looks like the door not being 100% solid on the striker vs chassis flex.
#7 | |
Drives: 2005 Toyota Camry
Doing this will result in (or bring up questions of): - stiffer chassis - altered crash/crumple zone characteristics - lack of ground clearance (even more than before) - how do you measure this without a review that says "it feels stiffer for sure"? - Who will pay for the R&D for a functional piece? Subframe mounting points are easy areas to stiffen up with minimal cost involved (i.e. no one will go out and R&D this, they just usually fab bars that fit/work). To do full unibody bracing, you're much better off seam-welding or fabricating a weld-in cage. -alex |
| Where to get OEM wiring connectors? | brianhj | Electronics | Audio | NAV | Infotainment | 8 | 02-01-2016 04:50 PM |
| REVIEW | DC Sports rear subframe brace / rear subframe lateral brace | mav1178 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 04-10-2014 09:59 PM |
| OEM Connectors | taylork057 | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 01-17-2014 02:00 PM |
| Connectors in trunk | retoocs | BRZ First-Gen (2012+) — General Topics | 4 | 07-26-2013 04:37 AM |
| Oem amp connectors | cruzinbill | Electronics | Audio | NAV | Infotainment | 10 | 01-31-2013 06:47 PM |
