Old 02-09-2015, 09:33 PM   #1
quark
Torgue App Cat Temperature
Can anyone confirm the temperature for Cat B 1 S1 (using Torque), after warmed up street use?
quark is offline   Reply With Quote
Old 02-09-2015, 10:42 PM   #2
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Usually cats like blankets and warm laps.
I havent checked the full functions of Torque yet, but why would you need to know the temperature during normal load?
Old 02-09-2015, 10:54 PM   #3
quark
I have a new 2.5" cat back and am interested on the affect of EGT, since we don't have any way to measure the EGT, closest is the cat temp.
Old 02-10-2015, 12:51 AM   #4
Poodles
Drives: 2015 Series.Blue
Cat temp is very very different than EGT. Running rich can lower EGT's but drastically raise temps in the cat.
Old 02-11-2015, 10:31 PM   #5
quark
It would be good to get consensus on the normal temperature range.
I have read that the cat temperature should be between 560C/1040F ~ 650C/1202F , street use.
Can anyone confirm this on Torque? Does EcuTek OFT show the cat temps?
Old 02-14-2015, 08:22 PM   #6
quark
Bump, can anyone please confirm the temps they are seeing... thanks
Old 02-14-2015, 08:58 PM   #7
TheVoiceOfReason
TheVoiceOfReason's Avatar
Drives: BRZ Limited
Why would the ECU have any of this information for any tool to tell you? There is no cat temp sensor. All that the ECU cares about regarding the cat is the second oxygen sensor to make sure it is working.
TheVoiceOfReason is offline   Reply With Quote
Old 02-15-2015, 04:38 PM   #8
quark
The ECU calculates the cat temp and provides this info as a PID.
You can get the value using Torgue and ELM Bluetooth adaptor.
I would like to know what the temperatures are with a stock exhaust.
Old 02-15-2015, 06:43 PM   #9
s2d4
s2d4's Avatar
How would the ecu calculate the temp?
Old 02-15-2015, 07:15 PM   #10
Akari
Drives: 2013 DGM BRZ
If the ECU is calculating temp it's going to be off by your exhaust change. If you want to know EGT then install a sensor, what you're trying to do here will not give you accurate(or useful) results.
Akari is offline   Reply With Quote
Old 02-15-2015, 07:54 PM   #11
lamawithonel
Drives: 2014 Subaru BRZ Ltd.
I've been running about 800-1100F on mostly highway and suburban streets. (35-70MPH cruising, very little stop and go, but a good deal of traffic.) Air temps have been 20s-40s, and I'm measuring oil and coolant temps in the 180-200 range once warmed up. The engine, intake, exhaust and tune are all stock. Fuel is 93 AKI.
Here's a chart of my most recent log:
*question everything*learn something*answer nothing*
lamawithonel is offline   Reply With Quote
Old 02-16-2015, 05:59 PM   #12
quark
Thanks for the detailed post.
What temperature do you put A/C on? FRiSson New England 23 06-13-2016 09:55 AM
Engine Temperature huffy044 Scion FR-S / Toyota 86 GT86 General Forum 4 01-13-2015 04:59 PM
E85 and oil temperature jvincent Engine, Exhaust, Transmission 11 11-12-2014 09:53 PM
Running Temperature? 350matt Engine, Exhaust, Transmission 13 10-29-2013 04:55 PM
Intake Air Temperature sw20kosh Forced Induction 18 06-19-2013 05:49 PM
