Drives: 2015 Asphalt FR-S
Debris in rear deck lid.
Wondering if anyone has experience with vacuuming out the rear deck lid. Some debris fell in there when my spoiler got installed, and I can hear little pieces when I open the trunk. I was going to try to vacuum it out, but the holes are rather small. I thought of rigging a vacuum hose with some duct tape and fuel line or other small rubber hose to reach inside. ?
how is the spoiler attached to the vehicle?
It's the optional factory spoiler, bolted on. I think it's just pieces from where they drilled that fell down and now are stuck.
Drives: JDL Turbo BRZ
Take if off and go fishing. Grab a magnet and side it on the underside (if you think they are metal pieces) up to the hole and pull it out.
JHerbert Racing
Drives: 2013 Scion FRS
This method works...I had to take out the drops from my spoiler too.
Oh sorry, I see the confusion now, I meant debris inside the trunk lid (I think), not under the spoiler, lol. I will try the magnet trick and if that doesn't work my vacuum idea.
Drives: 2013 Asphalt FR-S
I also hear the debris when I open the trunk and I have the factory spoiler too. I haven't done anything about it though... I am interested in seeing if there any quick fixes for this.
Drives: 2015 Series.Blue
Magnet should work as it should simply be from drilling the holes.
Drives: 2019 BMW ///M4
I had this happen when I installed my spoiler. If it's little metal flakes, my body shop used an air gun to blow then out and taped the holes and injected glue into it.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
#10 |
Drives: 15' MT FRS
I have debris in it too when I recently installed an oem brz spoiler on my frs. I tend to not give a shit because I'm not going to be opening my trunk 24/7 and listening to that crap.
#11 |
Drives: MY15 86 GTS
I injected glue when in the open position. After F'ing around for ages with magnets.
#12 |
Drives: 4wd zooks
Someone has a fix for this.
Attach double sided tape onto the end of a piece of thick wire and fish around. If the debris is not steel , magnets won't work at all , and because the boot lid is steel , magnets won't work very well anyway. |
#13 |
Fixed it. Did the tube attached to a vacuum thing. I think it just dislodged whatever it was, saw something fall out, rattle gone.
| Rear deck tick/pop | mankarn86 | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 07-17-2014 02:30 PM |
| WTB: REAR window top Brake Light (just top half with leds) or full rear deck | Kayzer Soze | Exterior Parts (Aero, Lighting, Etc.) | 1 | 08-31-2013 03:23 PM |
| Rear deck rattle - fix it in 30s | nzer | AUSTRALIA | 0 | 07-25-2013 05:09 PM |
| eliminate rear deck popping with rear strut bar? | chenshuo | Issues | Warranty | Recalls / TSB | 11 | 07-03-2013 07:44 PM |
| Wtb rear deck / headliner | jshadeck | Exterior Parts (Aero, Lighting, Etc.) | 0 | 02-03-2013 09:31 PM |
