Drives: 13 whiteout frz
Frs to brz headlight swap?
Has anyone done this swap by re-pinning the body Harness to a 8 pin. I have seen many threads about re-pinning the headlight but I just purchased brz lights and also purchased the 90980-10897 connectors. I am hoping to find someone that has a clear pin out of the body harness from frs to brz pin out. Also I would like to use the brz blinker location not the frs.
Drives: Raven GT86 & Subaru WRX CS6
I've done it:
![]() Attached are the wiring diagrams l made by looking at the FRS (worked for me as the GT and FRS share similar wiring) and BRZ technical manuals. Good luck! |
So you have 8 pin to 8 pin on your car?
Oh also how are you running your blinker?
My car (a GT model) came with a 6 pin, l rewired it to connect to the 8 pin BRZ harness. So essentially 8 pin harness to the 8 pin BRZ Headlight connector.
As for the indicator/blinker, l'm still using the standard FRS/GT blinker, but you can easily source the indicator wire and hook it up to the 8pin BRZ harness. |
Thanks I think I'm going to try to split the loom and rob the indicator wire for the brz light. Probably leave the other wires and turn the stock indicator to a fog light.
Just curious did the gt come with the day time running lamp resistor?
Trying to figure out what to do with it |
| BRZ Headlight Swap | AVodka14 | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 09-23-2013 12:17 AM |
| FR-S Headlight Bulb Swap | tennisfreak | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 08-29-2013 03:48 PM |
| Headlight Swap - FR-S -> BRZ | Acree | Southwest | 2 | 12-21-2012 09:44 AM |
| BRZ Headlight Swap? | ThePoet | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 11-19-2012 02:46 PM |
| Headlight Swap Question | nogaroblues4 | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 02-07-2012 03:45 AM |
