Old 11-20-2015, 11:33 AM   #1
Tvars
Tvars's Avatar
Drives: Firestorm
rattling inside engine bay near firewall driver side
Wondering if anyone else has had a rattling noise inside the engine bay on the driver's side near the firewall. This only occurs over speeds of 65mph.
When I first looked in the area there were 2 wires that go down along the engine bay using plastic hooks that had quiet a bit of slack so i tied them together to reduce the slack but the rattling continued.
Anyone else have this occur? or any ideas what I could check?
Tvars is offline   Reply With Quote
Old 11-20-2015, 01:08 PM   #2
Razzamatazz
Drives: 2015 BRZ Limited
I had this noise.. for me it was a factory defect in the form of a loose radiator. With the car stopped i could never tell but while driving it would rattle like mad. Once the dealership ran some tests & found the source, they tightened it down and i haven't had a problem since.. it could be worth a shot to check it. For what it is worth when i was in the car it sounded like it was coming from the firewall as well.
Razzamatazz is offline   Reply With Quote
Old 11-20-2015, 05:19 PM   #3
Tvars
Tvars's Avatar
Drives: Firestorm
Okay. thanks for the heads up. I will see if i can get in their and see if it's loose.
rattling
AP Racing Brake Kit - Loose Pads Rattling Inside Calipers MINOCIN Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 07-07-2016 04:40 PM
track driven car - Engine noise - click on driver side - vid philooo Tracking / Autocross / HPDE / Drifting 1 04-27-2015 09:09 PM
Engine rattling at idle Sketchi Issues | Warranty | Recalls / TSB 6 03-24-2015 01:15 PM
driver side Windows cant contrl by driver side button athlon816 Issues | Warranty | Recalls / TSB 12 12-13-2014 11:06 AM
Engine rattling/vibration happening between 3k - 3.3k Boofneenee Issues | Warranty | Recalls / TSB 4 05-18-2014 03:34 PM
