#15 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I have the very first run of the Quick Jack BL-5000 that had issue with the fittings (which were incorrect for the intended use)... fixed it myself with some aerospace grade Hysol Epoxy to bond every single threaded connection. I also wanted the AC version and was sent the DC power unit version. At least all that was required was to send it in and have them ship me the correct power unit. And then it took a while to get the thing working correctly because Rangers instructions were a complete joke and not even correct to the controls on the power unit, had to talk with one of their techs to figure out how to get it working properly.
That said, once I got it working it has been flawless ever since...simple hydraulic system should be pretty much flawless. It's VERY useful, can never go back to jack and jack stands anymore...leave mine permanently positioned under the center of the car in the garage until I need to use it, just this weekend used it to do some exhaust work, next weekend will do the oil change. Heck I even lift it if for no other reason than to look under the car and admire it...LOL It has safety lock bars and I have no issue being under the car without anything else, the weight is solidly on the bars locking them in place - they are not going anywhere. I use the 3" rubber blocks, positioned under the front seam weld jacking point and rear wherever it falls on the seam... car is very stable when lifted so no issues to worry about there. Only takes ~1 minute to fully raise the car and ~20 seconds to drop it down... take that jacks and jack stands! I wish these things had been made years ago...! P.S. I like the free moving safety bar system on mine, I use a tie wrap loop to secure them along the frame top when going down and let them out of the tie wrap look to run along the bottom channel and slip into the locking area when going up (better to gauge where you are at in the lifting process and fine tune the load going onto the bars when they are in place) Going all the way up: [ame="https://www.youtube.com/watch?v=Kq8h6ra9s2I"]BL-5000 going up - YouTube[/ame] Going down from all the way up: [ame="https://www.youtube.com/watch?v=HI9HX98Qx4U"]BL-5000 going down - YouTube[/ame] Note: for both videos the lock bars were tie wrapped to the frame as I was going up and down for the videos. Have done fluid servicing and tire rotation/brake inspection on my mom's Corolla, Sister-in Law's Kia, and my brother's Subaru Impreza RS... so easy!
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#16 |
We've been thinking of picking one of the variations of these up for the track. Probably not in our budget until next year though.
-mike |
#19 |
Drives: 2015 Crystal White BRZ Limited
I bought one of these for X-mas (the 5000 version) and I'm very happy with it. The nice thing is that it doesn't take up garage space because you can place it under the middle of your car when it is in the garage and drive back and forth over it each day. Then you move it out to the rails on each side to lift it up. I used it to change out brake pads and do a brake fluid change for my last track day and it was really nice. I also look forward to using it to change out gear and diff oils, oil changes, tire rotations, etc. The lock bars make it very safe and I like the idea of having two heights with which to lock the lift in place. Great product at a reasonable price.
#20 |
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#21 | |
#22 |
Drives: Whiteout FRS
#23 | |
Drives: '13 DGM BRZ Limited
#24 |
I've been using the BL-3500 (3,500 lb) for my BRZ for almost a year now. It's been reliable with no leaks, though I never disconnect the hoses. It's also very stable. The only thing I wouldn't do on the QuickJack is dropping the tranny, since I prefer to have more open space on the sides when doing so.
#26 | |
#27 |
Drives: 2013 SWP BRZ Limited
Thinking about getting a local thing going on. If anyone is in ny,nj, or pa that's interested pm me. After I get a rough head count I will reach out to retailers and see if there's some sort of bulk pricing.
Prefer locals only. Don't want to have to deal with shipping. |
#28 | |
| Car for $5000? | dem00n | Other Vehicles & General Automotive Discussions | 35 | 01-08-2014 04:44 PM |
| FS: 2013 White out Manual FRS under 5000 mi | Matt Andrews | Cars for Sale/Trade | 17 | 12-09-2013 02:00 AM |
| Clutch dump at 5000 RPM? | fasteddy | BRZ First-Gen (2012+) — General Topics | 20 | 08-22-2013 01:55 PM |
| Anyone else above 5000 miles too? | Superhatch | BRZ First-Gen (2012+) — General Topics | 32 | 06-28-2012 01:08 PM |
| 5000 to spend on what? | MtnDrvr86 | Other Vehicles & General Automotive Discussions | 29 | 03-18-2010 05:10 PM |
