| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: '13 black BRZ MT
Alignment specs for michelin pss
Im about to change my stock tires for pilot super sports. Is there a reason not to stick to factory specs?
#2 |
Drives: 2015 BRZ
No, assuming you don't have any particular goals or needs. Autox, track days, etc. You might benefit from a shop holding a tighter than factory tolerance, but the target numbers themselves can stay the same.
#3 |
Stock only has adjustable toe. So unless you buy parts like front crash bolts or rear lower control arms, toe is all you can change.
#4 |
All i have are crash bolts and eibach springs
#5 |
What do you mean by tighter factory tolerance? What is a good range for a somewhat aggressive daily setup?
#6 |
Drives: 2015 BRZ
Tolerance in this context means the allowable deviation from nominal. I believe stock camber for the front is 0°, ±0.5°. So you could ask your installer to get within a few tenths (0.1°-0.3°) of nominal, and you'd have a better starting point. That way when you make a change, you know what you're starting with.
#7 |
Drives: WRB BRZ
Since you have crash bolts I assume you want to get some negative front camber.
#8 |
Hard to say without knowing how you'll use the car. If you're doing track/HPDE or autocross, you'll definitely want to max out your front camber (negative).
2022 BRZ Build 2013 FR-S Build |
| Alignment specs | Thatguyjeremy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 05-06-2015 02:49 PM |
| Autox alignment specs? | normanb21 | Tracking / Autocross / HPDE / Drifting | 18 | 02-12-2015 08:52 PM |
| Alignment Specs? | 86_ZN6 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 06-10-2013 07:30 PM |
| Alignment specs? | russv | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 02-03-2013 11:16 AM |
| Actual alignment specs from BRZ | taosracer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 50 | 06-29-2012 10:33 AM |
