Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
Drives: Red Brz
Got a clunk/ knocking sound help please
It first started on low speeds I would hear a knock sound coming from the front right
But it got worse the front is now completely knocking so I jacked up the car tightened bolts (strut endlinks and the two 19 bolts) Still have the clunking sound I had my cousin drive the car slowly while I walked and he heard it inside clearly but when I was walking I didn’t hear anything I can feel the knock on the pedals Knock gets faster as the car moves I don’t think it’s the engine cus I don’t hear it when I rev or idle Also when I brake / slightly brake the sound is gone Don’t know if this looks good let me know if you see anything wrong Thanks ![]() ![]() ![]() ![]() |
#2 |
Mine developed a knock similar to yours after an autox. Some things I read in to forum were the two chassis braces in the engine bay and the lower aluminum engine cover. I torqued all these bolt on my car but the knock is still there.
#3 |
Drives: 2017 Toyota 86
I’m thinking of 2 things. One the bolts and top of the strut bushings in the engine bay. The other is a wheel/tire warp/rim or warped break rotor. Since ermax tried the engine braces. I would also check to make sure your fender bolts and engine mounts are tight and to spec.
I would also check that shock to see if it’s bent under the shock cover. |
#4 |
I did the shock towers and fenders. Need to check the engine mounts.
#5 |
Any update Bryan??
#6 |
Drives: Red Brz
#7 |
The Dictater
Drives: '13 Red Scion FRS
If it winds up not being the tie rod, check your brake caliper bracket bolts. I forgot to tighten one once and had the same exact symptoms you described.
The Following User Says Thank You to Spuds For This Useful Post: | Zentec (12-26-2017) |
#8 |
Drives: Red Brz
Thanks for the help but solved the issue don’t really know exactly what it was but my wheel studs and lug nuts were stripped a lot so I’m guessing my wheel was shaking or something and I reinstalled my right coil over and knock was gone
#9 | |
![]() ![]() Now, that's once ........ ![]() humfrz |
The Following 3 Users Say Thank You to humfrz For This Useful Post: |
Knocking sound | Moe23 | Issues | Warranty | Recalls / TSB | 80 | 04-18-2019 08:09 PM |
Unidentified knocking sound | Maarten | Engine, Exhaust, Transmission | 5 | 04-10-2019 11:40 AM |
Clunk/Thud Sound | Lakitu | Issues | Warranty | Recalls / TSB | 12 | 02-02-2017 12:58 PM |
knocking sound | wingrider | Engine, Exhaust, Transmission | 12 | 08-22-2016 12:35 AM |
Knocking sound from AC? | DCdesign2000 | Issues | Warranty | Recalls / TSB | 2 | 09-25-2015 09:09 PM |
