Old 09-22-2015, 05:12 PM   #1
DCdesign2000
DCdesign2000's Avatar
Drives: Civic Hyb, RS6, BRZ SeriesBlue
Knocking sound from AC?
Has anyone experienced some knocking noises coming from the Engine compartment when the AC is on and while gliding in neutral to slow down to a stop? I can feel a little bit of the knocking in the gear knob and brake pedal once or twice. Knocking is not constant. It's just once or twice similar to the old pipe in an old house when you turn the water on.
Knocking only occurs when:
1) AC on.
2) Gear in neutral (foot off the clutch).
3) Gliding and Slowing down.
4) Below 40 MPH.
Thanks!
DCdesign2000 is offline   Reply With Quote
Old 09-22-2015, 08:12 PM   #2
Nate.
Drives: 2014 Whiteout FR-S
Felt/heard something similar the other day. Turned AC off, it went away.
Didn't think much else of it after that.
These cars make weird noises.
Nate. is offline   Reply With Quote
Old 09-25-2015, 10:09 PM   #3
humfrz
1) AC on.
4) Below 40 MPH.
Thanks!
I suggest you just leave it in gear until you are almost stopped.....
"Georgia Overdrive" could get you into trouble ...... if your brakes failed ......
humfrz
(SOMEONE, get that OLD popcorn eater out of here .... !!)
Knocking sound Moe23 Issues | Warranty | Recalls / TSB 80 04-18-2019 09:09 PM
knocking sound holding around 3,000rpm radroach Issues | Warranty | Recalls / TSB 31 01-26-2018 02:03 AM
Knocking Raspy Sound from engine bay 914_WHITE_FRS Issues | Warranty | Recalls / TSB 60 05-08-2015 01:30 AM
Knocking doesn't sound good :-(. TheMarkness Issues | Warranty | Recalls / TSB 41 02-04-2015 11:38 PM
Knocking sound in wheels during driving WallsAndFoundations Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-28-2014 01:45 AM
