Old 03-12-2019, 08:39 PM   #183
Originally Posted by MuseChaser View Post
I'm sure you could pay them to do it, but a Subaru dealership is not going to honor a Toyota-issued recall which is what you have if you own a Scion. It'd be BIG bucks to have them do it, and it'd be way more fun and more cost effective to just drive your car and trust that it'll probably be fine.
Reminds me of a Nam story my younger brother (a Vietnam combat veteran) tells. The VC would pull the pin on a hand grenade then hold the handle down with a section of bicycle tubing then place it down the fuel filler tube and on into the fuel tank on certain Army vehicles.
In time, the rubber would deteriorate and allow the handle to fly off - 8-10 seconds later BIG BOOM - the grenade plus several gallons of fuel, exploding in an unexpected area.
So, when the vehicle drivers would hear something rolling around in the fuel tanks, they would get paranoid. In time, the VC discovered they could just put rocks in fuel tanks to send a vehicle into maintenance -
Old 03-13-2019, 11:16 AM   #184
EXCellR8
FR-S Driver (MT)
EXCellR8's Avatar
Drives: 2013 Whiteout FR-S
One of my very first inclinations when I first heard of this recall was that, if my car was affected, nobody was pulling my low miles engine unless it was Subaru or a boxer specialist--the latter of which would see me footing the bill. There's a couple in my area, who I hear were quoting up to $2000 for the labor. That's still better than being stuck with a seized engine and dealerships not honoring post-recall failures.
I feel like since ALL of the vehicles were built by Subaru that there should have been better coordination between the two companies to offer service using Subaru technicians, especially since there's a boxer engine here. Yes, I know that's not how dealerships work and means potentially longer wait times and a shortage of Scooby techs but the outcome would likely have been better.
EXCellR8 is offline   Reply With Quote
Old 03-13-2019, 11:23 AM   #185
An engine is an engine and any competent tech should be able to work on them. Subaru techs are not cloned for their inherent knowledge of the boxer. The screw ups on the sealant for the FA20 can be made just as easily by a Subaru tech as anybody else.
Old 03-13-2019, 11:24 AM   #186
Turbo
Drives: FR-S Turbo
This thread is SUPPOSED to be a place to document failures after the J02 recall being performed.
Not about "nam" stories, questions about idiot lights or anything else. All that shit does is piss people off who are trying to stay informed about this.
SO- would it be possible for an admin to delete all the useless shit in this thread and get it back on track? Perhaps post a disclaimer on page 1 that ONLY those affected are to post & comment.
Additional threads could be opened for EACH specific recall related failure for ppl to discuss with others here, but this thread as it currently stands just wastes time and pisses people off who are looking for FACTS.
There has been some significant press given to these failures in the past week and anyone coming here to research the issue will be greeted by this garbage.
Turbo is offline   Reply With Quote
Old 03-13-2019, 11:29 AM   #187
ermax
ermax's Avatar
Failure After J02 Recall - Discussion Threads
This isn’t the registry thread it’s the “discussion” thread. War stories are off topic I agree.
The “significant press” is just one of our members writing an article about his experience and posting links back to our shit discussion threads.
Old 03-13-2019, 11:29 AM   #188
They will also be greeted by skewed stats, opinions and hearsay which are almost valueless data. There are very few "FACTS" to be found.
Old 03-13-2019, 11:33 AM   #189
EXCellR8
FR-S Driver (MT)
EXCellR8's Avatar
Not necessarily. A technician who works with horizontally opposed engines on a day to day basis is probably less likely to miss key service procedures than someone who's more familiar with working on inline or V engines, or rotaries...
Sure, engines all perform the same work but are not all the same. Not really the topic of this thread though.
Old 03-13-2019, 11:35 AM   #190
The labor cost is in line with the recall. I saw the fully burdened invoice for my recall and it was just north of $2,000 labor. Easy enough to justify given the estimated time required in the work list and the multiply it by your shop's published labor rate.
Old 03-13-2019, 11:41 AM   #191
The boxer is not some mystery machine to techs.
Leaving chunks of sealant in the engine or applying it wrong are not issues that come up because the techs are not "familiar" with the layout.
Old 03-13-2019, 11:44 AM   #192
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Is your car affected by this? I didn't see you posting before about a failure. Relax This is a discussion thead, on a forum. While I do believe in professionalism, this is the thread that was made for discussion. Anyone coming here will already be acknowledging that this is a forum and that generally anyone can post here. Had you posted something constructive yourself, maybe that request would be acknowledged. Yelling "shut up" at someone you don't like typically does the opposite.
Old 03-13-2019, 11:47 AM   #193
EXCellR8
FR-S Driver (MT)
EXCellR8's Avatar
Quoted from "The Drive" article:
It has to be done in a very specific manner that's unique to the construction of the flat-four engine, a construction that's not found on any other Toyota vehicle outside the Scion FR-S and now the Toyota 86.
...is my point. It's a engine-specific procedure that is not present with other engine types.
Old 03-13-2019, 11:50 AM   #194
It is also detailed in such a manner that a 10 year old could follow it.
My point is that the procedure isn't the issue. It is basic and well laid out. The problem is sloppiness and that has nothing to do with the type of engine.
Old 03-13-2019, 11:54 AM   #195
EXCellR8
FR-S Driver (MT)
EXCellR8's Avatar
Yes, I figured this was an accurate quote and would only go up from there, especially if the work was being done by a 3rd party specialist. My gf lost her XV Crosstrek for over a week for a similar work order on the FB20 engine. The work was done by Subaru in Danvers, MA; the car seems good so far so I'm really hoping she doesn't run into anything.
Old 03-13-2019, 11:58 AM   #196
maslin
Benz Tech
Drives: 2017 BRZ Premium
Gluing this engine together might be special for Toyota, but everyone else has been doing it for 30 years. There is nothing high tech about the fa20, variable cams, direct injection, liquid sealant... old news.
Throw a 48v supercharger to spool the turbo, ditch the belt and everything attached to it, toss the starter in the trash and we'll talk about the new age of engines.
I can't believe how many times I've said this. Slow down. Follow the kindergarten level instructions. Don't blow up engines. And test drive the damn car when you're "done".
maslin is offline   Reply With Quote
brz, failure, frs, i cant even, j02, recall, so much glue
Registry Thread: Failure After J02 Recall DarkPira7e Issues | Warranty | Recalls / TSB 489 05-26-2023 03:46 PM
Is the fad threads ruining our fad threads? Andrew025 Off-Topic Lounge [WARNING: NO POLITICS] 12 10-04-2017 10:12 PM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 06:18 PM
BRZ or FRS (yes, another one of those threads) lisaaaxo FR-S / BRZ vs.... 19 04-11-2015 03:44 PM
Vs. threads.... TwinscrollGT35R FR-S / BRZ vs.... 34 05-22-2012 09:21 PM
