Old 08-26-2018, 08:45 PM   #169
phrosty
Originally Posted by Tristor View Post
I'm about to attempt this as part of my installation of an ATF cooler
Which cooler?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 08-26-2018, 08:55 PM   #170
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
Originally Posted by phrosty View Post
Which cooler?
The Stark Performance cooler. It's a Setrab core that mounts in the fog light well. I've already got the cooler mounted, I'm currently working on routing lines, but I'm not entirely sure what the correct path to follow is. Anyway, once I get it all routed and installed, then I have Redline D6 ATF to go in
I added a DIY guide for how to do the AFT fluid change to the DIY forum from the experience.
Tristor is offline   Reply With Quote
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 03:34 AM
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 03:23 PM
Mt transmission fluid swap bdanisi Engine, Exhaust, Transmission 8 02-08-2013 03:09 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 07:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
