Old 12-13-2012, 06:35 PM   #1
jmaryt
Drives: 2012 honda civic ex
Automatic Transmission Fluid Change
just found out froma toyota dealer that the "slush" box
tranny fluid requires a change-out at 100,000 miles initially,and then every 30,000 miles thereafter!.can anyone verify this?..thanks!
jmaryt is offline   Reply With Quote
Old 12-13-2012, 07:02 PM   #2
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
Given my luck with automatics, I'd change it out a bit sooner for piece of mind. YMMV.
86'd is offline   Reply With Quote
Old 12-13-2012, 07:58 PM   #3
OrbitalEllipses
Drives: Attitude
50,000 miles is a good number. My WRX wasn't changed until ~65,000 miles and it was NASTY.
Old 12-13-2012, 10:34 PM   #4
a.beck
Doing it wrong.
a.beck's Avatar
You're not going to hurt it by changing it too often. I'd agree with others saying sooner is better than later.
a.beck is offline   Reply With Quote
Old 12-14-2012, 02:27 AM   #5
jmaryt
thanks for the input! wondering what the manual says! got a feeling
it ain't 100,000 miles for initial dump! dealer 'knows" i am considering the "slush"
and "may" be tryin' to hit me with a s**t storm! i'm with you guys,change should be sooner! anyone know what's in the manual?..thanks!
Old 12-19-2012, 03:57 PM   #6
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
I haven't checked the manual either, but I recall back in the day my mecahnic always told me to change the AT fluid around 30k miles. But I figure with the advancement in fluid technology these days should have improved that a bit? Maybe 50k miles is a good figure.
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 12-20-2012, 03:16 AM   #7
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Yeah 40-50k should be good, the auto trans is one thing I do recommend sticking with the factory fluid. Do not use any ATF labeled "global" for sure.
JoeBoxer is offline   Reply With Quote
Old 12-20-2012, 01:52 PM   #8
zoomzoomers
So you shouldn't use something from motul or Royal Purple for the AT fluid? Hmm I'll keep that in mind.
Old 12-20-2012, 01:56 PM   #9
JoeBoxer
JoeBoxer's Avatar
I'm not going to, however if you end up with much higher than stock hp and torque you may want to use a high performance fluid i just don't know if there is anything compatible.
Old 12-20-2012, 08:32 PM   #10
getbent
Drives: 2013 FR-S Blue MT
If you want your slushbox to last you should probably change it frequently.
Many of the auto makers with "lifetime" ATF fluids are really only designed for ~100K miles. By that point they are out of warranty and not their problem anymore.
In any slushbox cars I own, I would change every 30K for peace of mind.
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 12-22-2012, 05:29 AM   #11
Anorexic 86
Trim the Fat & add Boost
Anorexic 86's Avatar
Drives: sometimes I fly
If you plan on doing this yourself... good luck changing it out correctly.
The process is harder than launching nuclear missiles.
I remember reading the instructions and thinking... WTF!!!
IT'S NO JOKE AND NOT AS SIMPLE AS DRAIN AND REFILL!
Check out the online BRZ shop manual listed in the sticky section of this thread for the instructions.
Again... good luck.
Anorexic 86 is offline   Reply With Quote
Old 12-22-2012, 05:53 AM   #12
JoeBoxer
JoeBoxer's Avatar
Again... good luck.
Sounds like the 370z auto trans service, it can only be done at certain temps to check the level or something. Basically good luck getting it done in the summer here unless you drop off the car in the evening so they can do it the next day.
Old 02-19-2013, 01:09 AM   #13
whataboutbob
AutoX-10/10ths every run
I've just been reading up on the AT fluids in our twins. It appears to be hygroscopic. Given that I've been AutoXing my car and done a dyno pull or 3 on it I'm thinking that I want to get it changed. Right now I have just over 20K on the car.
Can some of the more knowledgeable members chime in on what mileage would be best for a change interval?
Build thread:Here
Old 02-19-2013, 01:45 AM   #14
JoeBoxer
JoeBoxer's Avatar
I plan on doing mine at 30k, its cheap insurance and even if you drive like a grandma i would still do it at 45k. I drive mine pretty hard so changing the rear diff every 12-15k and trans fluid every 30k is a good idea if you plan to keep the car a long time.
This is just my opinion, no real data to back it up. I have been doing parts on the dealership level for 10 years now so i do have a little experience.
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 03:34 AM
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 03:23 PM
Mt transmission fluid swap bdanisi Engine, Exhaust, Transmission 8 02-08-2013 03:09 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 07:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
