Drives: 2015 BRZ Limited MT
Is there a front lip for BRZ that requires no drilling? (lines up pre-made holes)
Hello,
I'm looking for a cheap polyurethane lip for my BRZ that lines up with the stock holes at the bottom of the bumper - so no drilling is required. I've got a '15 BRZ which has the pre-made holes that fit the STI lip dealer option. Is there a lip (replica or otherwise) that fits these holes with bolt/nut instead of drill screws so I don't need to drill more holes into the bumper? thanks! |
Drives: 2013 satin white brz limited
Is there a reason you dont just go with that factory option sti lip? That will be the best fitting one imo.
Just another BRZ owner
Drives: 2014 Subaru BRZ Limited MT
I have the bayson r front lip off ebay which was only around $60. The lip itself has holes to use with self tapping screws (so no drilling itself is required but it will create holes in the bottom of your front bumper)
2014 Dark Grey Metalic Subaru brz limited 6 MT
Follow my Instagram @sal_brz |
#4 | |
Drives: 2005 Toyota Camry
It uses several of the larger holes in the bumper, but smaller mounting holes need to be drilled. The 2016 BRZ Premium that we have in our shop needed holes drilled for mounting hardware. -alex |
#5 | |
Weird, when i look under my front bumper i see about 10 holes all along the front of it (about 3 inches from the tip) ... I thought these were for dealer front lip. Now I'm wondering what the purpose of them is..
#6 | |
-alex |
IG: @HypeBRZ
Drives: Series.Hyperblue BRZ
No, they all come with the holes. They are indeed for the OEM STi lip, but oddly still requires drilling or self taps.
#8 | |
The rest (12x small bolts w/ rubber threaded inserts + 2x push rivets) all require you to drill additional holes. I've done this lip install 3 times with genuine hardware. My 2013 Limited and the 2016 Premium car I've worked on all have the same configuration. -alex |
| Tags |
| drill, front, holes, lip |
| Rearview camera without drilling holes | sav | Electronics | Audio | NAV | Infotainment | 42 | 07-14-2026 02:47 AM |
| DIY: Center Mounting the Front License Plate WITHOUT DRILLING | Neurytic | DIY (Do-It-Yourself) Guides | 28 | 05-14-2018 06:37 PM |
| Need Help Hooking Up my front plates w/out Drilling | Prinzsingson | Southern California | 18 | 02-25-2015 10:55 PM |
| Question on drilling new holes | WolfsFang | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 17 | 12-06-2012 09:02 AM |
| Front bumper drilling/plates | mooshoepork | AUSTRALIA | 5 | 11-18-2012 07:02 PM |
