Old 11-14-2018, 12:55 PM   #1
Gunman
Drives: 2019 Mazda Miata RF
Valve springs
So, reading some of the many 86 valve spring recall threads, got me thinking...
...in a inline, slant inline, V, or W engine design, if a valve spring breaks, it can "drop a valve". What about in a boxer engine? does it "toss the valve to the side"?
Gunman is offline   Reply With Quote
Old 11-14-2018, 01:34 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I asked this same question in one of those threads and I believe someone told me that the FA20 is an interference engine so the pistons could uppercut the valves if the timing is off (or if the valve springs fail).
Current DD: M235i
8RZ is offline   Reply With Quote
Old 11-14-2018, 02:41 PM   #3
humfrz
Yes, and depending upon which side it gets tossed to, when, - makes all the difference -
We didn't have this "valve dropping" problem back in the flathead days -
humfrz
Old 11-14-2018, 02:48 PM   #4
8RZ
The Gunshine State
8RZ's Avatar
Also, the RPM can play a factor as well.
Current DD: M235i
Old 11-14-2018, 02:54 PM   #5
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I have a valve story for you. Once I was helping a friend tear down his blown V8 in his boat (wife and he did speed skiing competitions). We took one head off and one cylinder was missing a valve. It was just gone. The valve got sucked all the way to a cylinder on the other side. Block and everything was mangled.
Old 11-14-2018, 03:19 PM   #6
humfrz
Was alcohol involved in that rebuild - ??
humfrz
Old 11-14-2018, 03:49 PM   #7
Sapphireho
Famous Potatoes
Sapphireho's Avatar
humfrz
Well, the blown and injected 500+ cubic inch chevy did run on nitro.
Old 11-14-2018, 06:04 PM   #8
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
The wormhole geometry going from initial conditions to final end point are doing my head in.
Was Windows vers.xx in the block involved?
Old 11-21-2018, 03:49 PM   #9
Gunman
I think I'll go back to the term we used at a previous employer, when a jet engine had a blade failure, and say that the "valve liberated itself".
PCV Valve Replacement with STI Valve apelpapa Forced Induction 30 06-03-2022 09:23 PM
Valve tick? Takumidesh Engine, Exhaust, Transmission 8 10-13-2017 03:35 AM
King Bearings (mains and rods) GSC Valve Springs Nick B-rz Engine, Exhaust, Bolt-Ons 2 07-23-2017 11:55 AM
Valve adjustment GsxrMe Engine, Exhaust, Transmission 11 01-14-2017 07:07 PM
Kelford Cams FA20 High Performance Valve Springs FT-86 SpeedFactory Engine, Exhaust, Transmission 26 09-26-2013 09:58 AM
