Old 09-17-2024, 08:12 AM   #1
theoc86
Drives: 2019 Performance pack
What are these connectors, DAB?
https://drive.google.com/file/d/1uRX...ew?usp=sharing
i just fitted my first headunit its a kenwood 5020DABS.
Its all working how i want it apart from my window stuck on DAB aerial and OEM mic. now i understand i will have to replace the mic as its connected into the main harness and the HU has small jack plug.
But the DAB aerial i assumed would fit but clearly does't, the only 2 cables left over are in the picture above, am i right in thinking the black one is the GPS and the white one is my DAB? obviously the connector wont fit my new HU is there a converter or can i take the white plug off and see if it fits in the DAB hole.
I have a 2019 GT86 Club series blue.
Thankyou.
theoc86 is offline   Reply With Quote
Old 09-17-2024, 04:49 PM   #2
tarzan_nojane
tarzan_nojane's Avatar
Drives: 2014 FR-S
To use OEM mic with sense and shield:
- supplied 5V to 28-pin pin 4 pink wire using 5V from a USB A male cable connected to HU
- add 3.5mm jack + to 28-pin pin 5 brown wire https://www.amazon.com/dp/B0BVPTFJN5
- add 3.5mm jack - to 28-pin pin 19 black wire
tarzan_nojane is offline   Reply With Quote
Old 09-17-2024, 05:18 PM   #3
tarzan_nojane
Drives: 2014 FR-S
My vehicle is a 2014, and the OEM connectors for GPS and antenna do not resemble those of your 2019.
Possibly helpful: there are 3 pins active for the shark fin radio antenna (+,-, and 12V ant power), and only 2 pins used for GPS antenna.
Old 09-19-2024, 10:58 AM   #4
theoc86
i will take a look at this, its really helpfull thankyou. as for the DAB i think i will just refit a replacement as its thrown me a little. the white connector does go off to the left over the glove box so i just assumed thats what it was, if it cant be converted ill just buy another stick on windscreen jobby.
OEM Subaru BRZ connectors kilohercas Electronics | Audio | NAV | Infotainment 5 01-30-2018 04:08 PM
Rods/connectors SimplyIcy Engine, Exhaust, Transmission 2 05-07-2016 10:32 PM
Subframe connectors? zooki Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-24-2014 03:17 PM
OEM Connectors taylork057 Scion FR-S / Toyota 86 GT86 General Forum 2 01-17-2014 02:00 PM
Oem amp connectors cruzinbill Electronics | Audio | NAV | Infotainment 10 01-31-2013 06:47 PM
