Drives: SUBARWD
Recommended tire pressure for Thunderhill
So I'll be at Thunderhill this weekend and I'd like to get some idea of tire pressure there in this temperature.
I am running the Bridgestone S04 with stock suspension. It'sgonna be fun! |
Drives: Scion FR-S/ Subaru BRZ
lots of variables in tire pressure...weather, alignment and driving style being the most important? Without getting into tire temp's I like to use the sidewall rollover test....if your hot pressures are too high you will notice the sidewall might only be half or less used....drop pressures until the sidewall is being worn, but not too far...only the tread part...not the actual sidewall itself....
I have seen heavy powerful cars that come in with literally the tire name scrubbed off...that is SCARY.... I ran my bone stock FRS with stock tire pressures....then I dropped them later in the day and grip improved.... |
Drives: SUBARWD
That's a great tip. Thanks!
Drives: 2013 WhiteOut FR-S
different tires have different characteristic with different tire pressure, a general rule I would say keep all tires <38 psi hot. I run Rivals and its more stickier with 36 psi hot so I set 32 psi cold when I first arrived at the track and adjust after each session
2013 Scion FR-S whiteout 2012 Porsche Panamera S carbon grey 2008 Range Rover Sport SS black - sold 2004 BMW M3 alpine wies - sold |
| tire pressure | mrnibbs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 10-18-2013 11:09 AM |
| Tire Pressure | Fallen43 | CANADA | 2 | 10-12-2013 01:46 PM |
| what is your tire pressure? | abling2 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 06-03-2013 11:49 AM |
| Recommended Tire Pressure for Aftermarket Wheels and Tires | Chri5 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 05-15-2013 02:28 PM |
| What Hot Tire Pressure? | gbgracer | Tracking / Autocross / HPDE / Drifting | 24 | 05-14-2013 06:47 AM |
