turbo FT-86
Drives: ft-86
Spark plug type and heat
hi,
any of you guys check'd what type and heat range is the stock spark plug on the ft-86? are they Denso or NGK? and what heat rage are they 6 or 7. Thanks, |
Drives: car
short answer: The FA20 appears to have a 9 heat range, while the Lexus IS350 2GR-FSE engine appears to have a 6. A 9 is significantly colder than what you would find on an STi or a Supra from the factory.
more detailed answer: It's a Denso ZXE27HBR8 plug. That's a Denso 27 heat range... Denso uses different number range than the more commonly understood NGK system. Here's a conversion chart I found on sparkplugs.com: The chart indicates the stock plug for the FA20 would be a 9 heat range on the NGK scale. When I first read that, I'll admit I'm skeptical. Now I haven't looked extensively at heat ranges for direct injected n/a engines. But I can't think of a mass produced passenger car engine using anything that cold when stock except with a rotary engine, and only then in the trailing position. I was thinking more along the lines of a 5 or 6 on the NGK scale as well. The coldest you'll see from the factory on even boosted engines is usually about a 7. You'd think it would foul out with a 9. But here's something to consider. Do some Googling and you'll find that the 2GR-FSE engine in the Lexus IS350 (using an earlier version of the D-4S direct injection system) has a Denso FKB20H plug. If you cross-reference that with an NGK plug at RockAuto, it lists NGK spark DFH6B11A (6 heat range on the NGK scale). So that's two sources (including chart above) saying that an NGK 6 corresponds to a Denso 20. So maybe the FA20 spark plug heat range is close to an NGK #9 after all. |
Toyota Service Writer
Drives: Whiteout M/T, 2003 Duramax
Has anyone seen what it takes to change spark plugs in one of these cars? If not Google it. Pretty ridiculous.
Whiteout Manual
I'm a service writer at a Toyota/Scion dealership, if I can help at all let me know. |
Drives: car
This isn't the only vehicle that requires you to remove the engine mounts to change spark plugs. Rear plugs on V8 vehicles can require that. With factory irridium plugs, even with boltons it shouldn't require new plugs for years.
| Subaru or Toyota drain plug? | yayforaddison | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 05-06-2020 11:59 PM |
| spark plugs | subaruferrucci | Engine, Exhaust, Transmission | 22 | 04-10-2013 12:24 PM |
| LEDs that convert heat directly into light... | serialk11r | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 03-10-2012 01:08 PM |
| Car won't start, no spark? | #87 | Other Vehicles & General Automotive Discussions | 5 | 12-19-2011 01:29 PM |
| Jowett Jupiter/spark plugs | aspera | Engine, Exhaust, Transmission | 6 | 02-25-2010 06:47 PM |
