Old 11-02-2015, 03:06 PM   #1
slowbrz
Drives: '13 black BRZ MT
Alignment specs for michelin pss
Im about to change my stock tires for pilot super sports. Is there a reason not to stick to factory specs?
slowbrz is offline   Reply With Quote
Old 11-02-2015, 03:26 PM   #2
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
No, assuming you don't have any particular goals or needs. Autox, track days, etc. You might benefit from a shop holding a tighter than factory tolerance, but the target numbers themselves can stay the same.
GSpeed is offline   Reply With Quote
Old 11-02-2015, 03:32 PM   #3
swarb
Stock only has adjustable toe. So unless you buy parts like front crash bolts or rear lower control arms, toe is all you can change.
Old 11-02-2015, 04:02 PM   #4
slowbrz
All i have are crash bolts and eibach springs
Old 11-02-2015, 04:03 PM   #5
slowbrz
What do you mean by tighter factory tolerance? What is a good range for a somewhat aggressive daily setup?
Old 11-02-2015, 04:08 PM   #6
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Tolerance in this context means the allowable deviation from nominal. I believe stock camber for the front is 0°, ±0.5°. So you could ask your installer to get within a few tenths (0.1°-0.3°) of nominal, and you'd have a better starting point. That way when you make a change, you know what you're starting with.
Old 11-02-2015, 04:23 PM   #7
Vmax911
Drives: WRB BRZ
Since you have crash bolts I assume you want to get some negative front camber.
Vmax911 is offline   Reply With Quote
Old 11-03-2015, 09:10 AM   #8
DarkSunrise
DarkSunrise's Avatar
Hard to say without knowing how you'll use the car. If you're doing track/HPDE or autocross, you'll definitely want to max out your front camber (negative).
2022 BRZ Build
2013 FR-S Build
Alignment specs Thatguyjeremy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-06-2015 02:49 PM
Autox alignment specs? normanb21 Tracking / Autocross / HPDE / Drifting 18 02-12-2015 08:52 PM
Alignment Specs? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-10-2013 07:30 PM
Alignment specs? russv Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-03-2013 11:16 AM
Actual alignment specs from BRZ taosracer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 06-29-2012 10:33 AM
